Alarm keeps going off
Not sure what to do. I replaced batteries but still get alerts on both the panel and the alarm itself.
It looks like you may be referencing the Smoke Master BR labeled sensor, is that right? I see it has a malfunction currently.
The offline malfunction and beeping from a smoke detector does not always mean low battery.
If you have a PG9936 (looks like that is probably the model based on age and programming) then it will beep and flash its LED in different patterns to indicate the fault:
  • General Internal Fault: Yellow flash every 4 seconds One chirp every 48 seconds
  • Detector Dirty: Yellow flash every 8 seconds One chirp every 48 seconds
  • Low Battery: Yellow flash every 12 seconds One chirp every 48 seconds
What is the interval of the LED flashing?
Let me know if you are instead referencing a different part of the system.
