Zwave repeaters are added into your panel as any Zwave device would be. They will naturally repeat all signals routed through them to distant nodes.
Double click the button on the side of the repeater quickly. As with any Zwave device, it is recommended to use the “Remove” function first. On Qolsys this is labeled as “Clear Device”
Make sure to rediscover the network after any new Zwave device installation.
Jason, I tried this at the time I wrote the original post and had no luck - not sure if there was a recent update that fixed any zwave problems but this issue and another issue I was having with zwave was resolved about 5 days ago.
My thermostats (problem discussed on another thread) started communicating with the panel again 5 days ago after I had given up for a few months and not had time to fix it with a new kid just being born.
I started thinking it was a zwave issue with the panel - anyway, since the thermostats started communicating, i plugged the repeater in, hit pair on the panel, double tapped and it worked flawlessly.
Very strange so I hope there was a recent update that fixed it!
