For over a year my ADC-V520IR has not been following set schedules. I have tried deleting the schedules and the camera and after restoring, the schedules work again fow a few days, then stop. I can access the camera for live view, but again, it does not record. Other cameras do follow the schedules. Any insight on how to correct it, would be appreciated. Thanks.
RM
EDIT: It turns out (sorry, completely forgot) I had stared the same basic thread over a year ago.
A new firmware version is being developed to resolve the issue fully, which should be available in the near future.
We can notify Alarm.com that your system is seeing this error and they can monitor the connection, should the connection to the recording server be interrupted, they can send a remote reboot command to the camera (so you do not have to power cycle).
Nope, Alarm.com will have that info. If you have multiple cameras and only one is showing this issue, let us know which, otherwise I’ll notify ADC that the V520IR on your account is showing signs of the same recording server syncing issue.
Yes, there have been a couple firmware updates targeting services in the cameras to resolve these issues, but there are a couple still outstanding.
To confirm this issue is what we expect, can you provide a description of when the failures occur? Is it on VMD schedules, sensor trigger schedules? When a schedule fails to upload video, does a power cycle immediately resolve it?
Also, the next time you notice this state, when the camera is not uploading video, can you let us know then and we can have Alarm.com pull some logs from the camera. That will give us the best insight into the issue.
This is the current FW on the camera. Is that the latest?
IP8136W-ALAM-0101f2
The original issues was that it would not record when a sensor was opend and when the alarm was triggered. This last time, the alarm was triggered and it did not record. I did just check that it does record when the sensor is opended.
Yes, that is the latest firmware, but I think we may be getting ahead of ourselves. The last alarm event appears to be the 8th, correct?
I see both cameras showing clips from that event. Note that the HD100 splits the clips up into 3 labeled event triggered, but those are due to the alarm occurrence.
Could you specify when you noticed a schedule error?
