A work around may be to reprogram your PIR motion as a zone 23 contact (so that it shows as a selectable sensor in the sensor left open energy saver rule), then set back temp for that tstat configured zone when the sensor is triggered. Not configurable for set forward temps though.
A tricky part about using motion for thermostat activation is they power save delay and activation delay in ADC. It is much more precise to use things like arming status and Geofencing.
Currently, if you relied on occupancy as detetmined by a motion detector, a lack of occupancy wouldn’t be noticed for quite some time, and your HVAC would blast away for up to an hour after everyone leaves.
The use case you bring up is interesting though and wouldn’t be served by current options. We will discuss with ADC. They may already be working on a solution.
Yes, I am confident this will eventually be a feature. Alarm.com used to have a feature called activity patterns where the thermostats page would graphically show you what days/times during the week you were most likely to be home based on activity from all your sensors. That feature was removed with the recent thermostats overhaul but they are planning to bring activity/occupancy based automation back in the future along with the planned scene functionality.
