2gig panel lost all z-wave devices
There is a rare but known issue that affected 2GIG Panels on older firmware, but this would be the first time I think I have seen it on 1.17 or later. I am sending this info to 2GIG for review. So I can give them as much info possible:
  1. Does your panel have symbols under the emergency button or does it spell out “Emergency” on the front plate? (This determines panel hardware version)
  2. Was the outage the result of a storm?
Unfortunately, it is in fact a rare error resulting from an outage/power surge that affects the Z-wave radio and essentially resets the radio.
Z-wave device configuration cannot be backed up the same way sensors can due to how Z-wave functions. Z-wave devices must always be learned in locally at the panel.
The devices themselves will retain the parent network link, but a new one must be established. To re-learn devices, first use the Remove Device button on the panel (Services > Z-wave > Wrench Icon > Installer Code > “remove devices”) and go to each Z-wave device and activate it to send a signal to the panel. The panel controller will then clear that device’s parent network link. You can then select add devices and do the same thing to re-add.
Unfortunately there would be no other way to recover the data.
