I have had the system running the way its wired and working fine well before starting service with surety ( so well over a year or two)
The panel from the alarm box is about a , 30 foot distance. Never had a issue before.
It is possible. A few days ago I unplugged a deal in the attic above/ near that panel.
I plugged it back in. But that was a few days back. I was looking for a power plug for a secondary panel I had. ( found it with my tracer) but it ended up being a gc2 secondary and not compatible with my gc3…
I will go up in the attic and look to see if it possibly fell out of the plug.
The only power wires I see in the box come from the battery and looks like a pair of wires going into the wall. I can trace them , if needed.
Just odd, out of the blue. When nothing happened. I have tesla powerwalls , so I am never without power . And use surge protectors .
I will go check that plug up in the attic, than properly power cycle the gc3 panel and see what happens.
And is it possible for me to get a backup of my programing configuration? Just in case I will have to replace . Or something else happens . It took a long time to do it.
Glad to hear you were able to get the sensors reporting again.
Loss of supervision occurs when the panel doesn’t receive a “check in” signal from the sensor. This can be power related or distance related in most cases. In turn, sensors will report malfunction in ADC.
In this case, it appears to have been every TAKE-345 connected. To verify, are all sensors in your system wired and connected to TAKE-345s?
Per your request, commands have been sent to pull a backup to save in ADC. This can be pushed to the system at a later date if necessary.
