I need help. I’m trying to do the initial config of the system and stuck in a loop configing RF sensors. It asks what sensor number then question number then back to what sensor number. I can’t select sensor type or any config question beyond that.
I can see that you had about 10 or so sensors learned into the panel but that you have recently deleted them.
-Are you trying to learn the sensors in from scratch?
-Which question in programming are you getting stuck on?
Yes I dumped all the sensors that were previously loaded. Using a Vivant panel from a previous system. I got it figured out. User error. Thanks
No problem. Shoot customerservice@suretyDIY.com an email to Let us know when your sensors are configured. That way we can get your central station information up to date.
