I need help with the 2 gig go system wiring or programing?.
System is old. I had it on few yers ago.
After system was removed by tech when he installed new system (he took most components from this system. Only left the 2gig control panel). I both 1 take over module and hard wire conversion kit ( plastic box power supply board with transformer and 1 take over module). I had to hard reset 2gig panel because it had custom installer code. I wired everything acording to the manual and programed 2 gig panel?.
Everything looks normal. System can be arm and disarm, but system doesn’t see open or close sensors (doors or windows. I didn’t wire or program motion or other sensors yet)
After few hours on (unarmed) system start biping and show alarm lost supervision on all conected sensors.
I made pictures but it is hard to see all wiring.
On power supply board i have:
2 top black & red connected to the ac power adapter = 19.1 volt
2nd 2 from top black & red (2red & 2 black) go to the 2 take over modules
DC+ (red) go to the 12V on the take over module
DC- (black) go to the GND on the take over module and to the all GND from all wired sensors. When i probed DC+ & DC- i got 0 volts?
2 lowest BAT- black go to the battery negative
BAT+ red go to the battery positive
There is 13.1 volts.
All red wires from sensors are connected to the take over module terminals 1-8.
Thanks.
